John Ehricht
Does anyone have a 36 with a Doyle Utility Power Sail? We found out about this sail on this forum and then contacted Doyle. It sounds very good, however we have some questions about how it fits on a 36. Doyle explained that it attaches to the hole in the anchor roller where the pin goes through and then goes up the mast where the spinnacker halyard is. We already have a spinnaker halyard, but it was installed by the dealer and not at Hunter. The halyard does not go to the top of the mast, but it is maybe about a foot higher than where the foresail is attached. Extending the halyard down to the anchor roller would require the halyard to go under the bow rail. So our question is, does the sail start above the bow rail and then stay clear of the bow rail? This would put the Doyle UPS about a foot from the foresail in parralel to the mast at about the same angle. So, is our Halyard installed in the correct position on the mast? Has anyone with a 36 actually acquired one of these sails and used it. We will appreciate your comments.
