Doyle stack pack
NCBrew
Feb 22, 2010
78
Hunter Hunter Legend 35.5 9335 Albemarle Plantation, NC
I have a Doyle stack pack and it is difficult to stuff the mainsail down into it, I would have thought the sail would simply fold down into it but it does not.
Any suggestions?
Jan 7, 2011
5,675
Oday 322 East Chicago, IN
I have a Mack Pack, but pretty similar.
My main sail is pretty new, and pretty stiff. I have to stuff it into my bag, but a few things can help…
1) if you have lazy jacks, keep them fairly tight when dropping the sail. For me, it seems channel the sail into the slot in the bag, so it doesn’t fall out on either side.
2) make sure the sail slides and sail track are clean and lubricated. I have a Tides Marine track, so it is pretty slippery. Having the slides and track clean and lubricated will help the sail fall faster and more completely, getting more in the bag on the drop.
3) On my set up, the slot in the bag is pretty tight right at the mast (not sure if the Doyle is the same). If I loosen the bad where it attaches to the mast (at least the top 2 snaps), the sail gets deeper in the bag without the need to stuff it dow.
The convenience of the bag and lazy jacks is priceless to me. I usually drop my main and get into the bag before heading into the marina. With the boat on AP, I can have sail in the bag, zipped up, halyard secured, traveller pulled to the side and have the boat ready to leave in her slip before I get back into the marina.
Good luck,
Greg
Sails have to be trained to go into any of the stack packs. I have a Mack Pack and a new heavy stiff mainsail. The first half dozen times it was a challenge to get the sail in. As Greg mentions, tighter lazy jacks help but not too tight and working from the clew end to stack the sail works better than trying to get it all from the front of the sail. Keeping the boat headed into the wind is essential, if it falls off the wind can blow the sail off to one side.
