Downwind Trim
Mike,When the apparent wind moves aft of the beam, aerodynamic lift becomes less of a factor and simple air pressure on sails takes over. Sailing dead down wind most likely will not give you your fastest VMG because the main cannot be squared to the wind due to the lower shrouds getting in the way. Most likely, you will not be able to go deeper than 160 to 170 degrees off wind. If your leeward mark is DDW, figure on doing a couple of jibes - you'll still be faster than if you sailed the rhumb line. Tie a tell tale over your head on the back stay and steer/trim to it. Your leech tell tales should either stream out or curled to leeward. Main sail trim: The boom should be perpendicular to the wind in order to present the greatest surface area to the wind. Ease out the traveller first, then the mainsheet. Vang in to lower the boom and keep the sail flat. Ease the halyard and outhaul. Jib trim: Ease halyard . Move the fair lead up and out to widest part of the boat. Unfortunately, the ideal position for the fair lead is several feet out over the water so a pole is needed to set the jib during wing on wing. As a starting point, the pole should be 80-90% of the sail's LP. There is no real compression force on the pole so it can be considerably lighter than a normal spinnaker pole. The pole should be perpendicular to the mast. A topping lift will keep the weight of the pole from pulling down on the jib's clew and can make the jibing process easier. (This is more important if you are using a spinnaker or large whisker pole. Not so important if you are using a "jib stick".) I trim the pole back with a guy so it is on the same plane as the boom (and off the forward lower shrouds). I make my fine adjustments with the jib sheet. The guy and topping lift will allow you to trip the loaded jib sheet from the pole, jibe, then reset the pole on the other side without having the pole bang around on the headstay or deck. I also try to trim the boat's balance by moving the crew slightly forward and induce a little heel to reduce the wetted surface. I used to crank up my 22's centerboard to reduce wetted surface. You will still have enough of a skeg to steer the boat. Rig a preventor on the main if there is chop or rolling swells to reduce the risk of an accidental jibe. Most cruising spinnakers are designed to reach and do not perform well poled out. I never had much luck poling out an asymmetrical.
