Righting moment
The righting moment can be measured, or it can come from calculations.It is only important if you are designing a rig, racing, or a techno-file.In the range of heel that moat boats sail well (0-25 deg) the RM curve is linear. If you figure out how much weight it takes to heel the boat 2 or 3 degrees you can plot the line.If you want to measure your boat, you can do it by yourself but a couple of friends helps. Take a bucket and half fill it with water. Make a plumb bob and suspend it from the cabin roof with the weight in the water bucket (to keep the weight from swinging wildly). Tape a ruler to the top of the bucket (athwartship) as a scale, the string is your pointer. Measure from the top of the string to the ruler and make a note of the distance. Have one person sit in the middle of the boat where they can read the ruler without moving. get everyone off the boat and let the boat settle down. The recorder centres the string and notes or marks a "0" point. Have a friend stand on the rail and let the boat settle down again, make another mark on the ruler. Keep adding friends until the boat is heeled enough so the weight is up against the side of the bucket or you run out of friends.
Now to make enemies. As each person steps of the boat, have them stand on a scale and record their weight (if you ask their weight, they will lie. If you ask to weigh them before the test, they might not want to play).Measure the distance from the centre of the boat to the rail. Multiply that distance by the weight and you know how many foot/pounds of force each of your data points represents. Some simple math will tell you how many degrees you heeled the boat from the amount the string moved on the ruler.Plot these points on a piece of graph paper and you have the RM curve for your boat.If you want to do it without making enemies, you could use water jugs and weigh them, but 5-6 guys standing on the rail then bitching about their weight is *much* more fun.
Say you had 5 guys at 200# each standing on a rail that is 5 feet off centre (half the beam). That would equal 5,000 foot pounds. If the boat heeled 5 degrees, the RM at 10 degrees would be 10,000 foot/pounds, 20 deg = 20,000 foot pounds etc.What use is this? None, unless you are changing the rigging and need to know what number to use to select wire sizes.BTW, compression load is (RM30 x 1.5 x 1.85) / 1/2 beamFor a 12 foot beam and 30,000 ft/lb that would be about 14,000 pounds compression.It is also of some use in tuning at the dock. If you know RM20 (20deg) and measure out to the upper shroud you can figure what tension the wire will be at 20deg heel. If you have 20,000 ft/lb RM20 and the upper is 5 feet off centre you get a total of 4,000 pounds tension in *all* the shrouds. Single spreader rigs have about 45% of the load in the upper. The upper will have about 1800 pounds of load at 20deg. If static tune is set to 1800 pounds, the leeward upper should be just slack when the boat heels 20 degrees under sail. The shroud in this case could be either 9/32" 302 alloy or 5/16" 316 alloy to have static tune between 15% and 20% of rated strength.Brion Toss' book, Rigger's Apprentice is a good read if you are into this stuff.Randy
