Weatherboards vs doors.
I think doors can look very cute but they must NOT be relied upon to be a substitute for weatherboards in bad weather. One good comber over the transom will stave them in in an instant. At least with weatherboards the grain is across the opening and will have some spring in it first.Also, they might not be as resistent to break-ins. Most non-boating thieves are puzzled by padlocks and weatherboards. They will break in the foredeck hatch first. Louvred doors are very nice in port and when you are aboard; they are not so safe when you are away or at sea.My dad designed several 'character' (traditional-styled) boats and one of his trademarks was that the companionway had a negative angle-- that is, the top of the companionway was further aft than the bottom (at the bridge deck). In this arrangement a set of louvered doors works very nicely-- with the hatch drawn they are out of the rain and can even be left open at anchor with nothing coming inside. He also drew the companionway rails to be deeper than necessary so that weatherboards could still be fitted inside the louvred doors, and the doors could be removed for sailing at sea. This makes sense and if you can fit this arrangement on your boat, there is your answer.You can always make a second and third set of weatherboards for different occasions. Have one a single sheet of plywood with a large screened opening. Have another one entirely of Lexan for the light. Have the proper separate sections of solid-wood weatherboards for at sea. They do not take that much room to store on board and the versatility makes you feel very pampered.Again, I would not recommend entirely replacing the weatherboards with a dainty set of panelled or louvred doors. If you can't still use the weatherboards, don't do it.JC 2
