Single Reef Breezes . . .
FWIW, as I am no expert except that my 9 year old son "Whitecap Jeff" and I like a single reef breeze - at least on a lake with sea to mess us up."Should we still tension to keep the top batten parallel to the boom?" I guess if you can - but with it blowing, especially if gusting - I think you will want to add twist, spill air off the top of the sail - also this gives the sail a wider groove - only part of it stalled or luffed at a time. Gusty shifty winds are hard to get a groove for, so I aim for some sort of average & keep as much average drive as I can while limiting heel."Any cunningham? I assume we want lots of halyard tension." As Don said - lots of luff tension, to flatten and aid twist."Do the telltales still provide the same, or any, information?" I think so - but most of the time I am too busy to look - and correcting for heel and control rather than the nuance of a streaming telltale. Most of my sailing in these conditions is by feel - still as a stalled sail is no good - I think some or most the telltales will continue to stream. If you are spilling air at the top then maybe those won't stream - but the lower ones will.Generally I will set the vang for some sort of maximum twist that looks OK to my eye, and sheet for a better shape when I can & ease the mainsheet when I need to. The vang keeps the sail from folding up into a bag, the traveler is set to the max I can sheet in to under the conditions and point of sail, usually I sheet out with the mainsheet at this point as it adds twist up to the vang limit, then is a travel out & I can only handle one line and the tiller at a time.Bear in mind I am sailing boats (J22, NACRA 5.8) where it is easy to hold mainsheet and tiller and control one with each hand.Perhaps an expert will have a better way to do it?Cheers, Kevin
