Rob R
Well, I must have stripped the bleed screw the last time I tightened it. This time, on removal, a small circle of metal came out with the screw. When I tried to re-tighten the screw it was pretty plain to see that it was stripped. I was able to re-start the engine, but fuel now leaks out of the bleed screw - so it's basically finished. The Bleed screw is on top of a Fuel Filter housing at the front of my 2 cylinder Volvo diesel engine. The housing is the standard type - bolted to the engine head with a vertical cylinder that that filter screws on to. The screw itself appears to be sturdy steel - probably stainless or similar hardness. It appears to be a good bit harder than the alloy that the filter housing is made of. I thought about replacing the filter housing, but it looks like a rather involved process.What do you recommend? Re-tap? If I did that, I could get a new screw and modify it with a vertical slit (which would allow it to bleed fuel). I have never tapped a hole before - just wondering if re-tapping would allow a fit tight enough to keep fuel from spurting out when priming and bleeding. Anyone else been in this position? Or a similar position where you needed to retap a hole and put a screw of a larger size into it (where pressure is involved)?Thanks for the help. I am planning to take her upriver this weekend on a 6 hour jaunt - but she's not going anywhere if I don't get her fixed
Rob
