Last fall when I hauled out, I noticed for the first time these whitish deposits around my bronze thru-hulls, the bronze seawater strainer, and a few spots on my cast iron keel. Oddly, it didn't appear around the bronze prop strut. Four seasons ago, I stripped the bottom and applied seven coats of Interprotect, which I also applied to the exposed portions of the thru-hulls and the keel. We use VC-17 bottom paint, which has copper in it. We are in the middle of a mooring field, not in a slip so I don't believe an external source could be the cause. We probably connect to shore power overnight twice a season just to charge the batteries. I sanded one of the thru-hulls yesterday, and it still has all the coats of Interprotect on it. I am wondering if this is electrolysis, or something else?
The only factors I can think of in the last season that changed that could affect anything electrical were:
1) We replaced our inverter with an identical model ( it is the portable kind that we plug directly into, it is not wired into the house AC system)
2) I re-wired the glow plug system with the solenoid per the instructions in the Catalina wiring upgrade on the C-34 site.
3) I had the mast unstepped for the first time since I have owned the boat.
Any thoughts/suggestions?
Thanks,
Scott
Thanks,
Scott
