...where to get the little rubber inserts that keep the shrouds from coming out of the mast ('87 h23 Z-Spar) when your raising it, I've lost 3 of the 4. Thanks in advance.Dave h23 "Wind Dreamer"
Hello Dave,I do not know which part you are talking about, but you should try rigrite, they carry most parts from various spar manufacturers.http://www.rigrite.com/Spars/Zspar/Z_Z-SPAR.htmlGood luck
Hi Dave:Several of us had a long discussion on this topic on the H26 forum recently. Despite my best efforts, I cannot find the most recent posts.I recently purchased a 94 H26 and was missing a T Ball plug. I searched the archives and found the following link to order them. I ordered from their website and the service was great. In retrospect, I wish I had phoned them to verify I was ordering the proper size.It was VERY difficult to seat the new plug and I ended up using a razor knife to cut a channel just below the rim to insure the plug would seat properly. Worked fine. I'm 99% sure that a Hunter recommended supplier was mentioned in the recent thread I mentioned earlier... but I can't find it now.I recommend you call Hunter and ask them for specific size and and supplier name.
got 'em coming. Jandelbert your website was great, I had already tracked them down thru Z-spar from a company called SECO (727-536-1924) I wish I had waited though, annapolis was about fifty cents cheaper per plug. Thanks again.Daveh23 "Wind Dreamer"
and size dependes on your wire size. Go to the annapolis site, search for t-ball fittings as the keyword and you will pull up a list with all the different sizes and appropriate part numbers.Fair WindsDaveh23 "Wind Dreamer"
