My current berth:
- Usually has a moderate to strong crosswind that moves my boat in the same direction as my very strong reverse prop walk. Very quickly.
- Floats low to the water;
- Has minimal flotation, so when the under-curve of the hull presses against the berth finger corner, the corner is forced down and my boat can ride up over it.
I usually sail solo or with people that can't safely fend the boat away from the dock before stepping up the three feet onto the boat at the last moment. With the crosswind and the prop walk, occasionally my boat will ride up over the dock enough that the reverse engine propulsion can't overcome the friction between the dock bumper and the hull. Then I have to shift to forward, go back in and start all over.
Does anyone use dock wheels at the corner of the dock finger -- like pictured here? Will one assist in my case?
(End note for respondents: Regarding advice that that I improve my skills at minimizing prop walk -- or that I could do a line on the opposite side to cast off the cleat with a perfect flick of the wrist at the right moment every time when backing out. Won't work. Almost no matter what, a 10-15kt cross wind will blow me onto the opposite dock corner within a few seconds of releasing the upwind dock lines and before I have enough backward speed. Plus, I don't have the requisite degree of precision coordination to flick a line off a dock cleat from the cockpit every time.)
