Do You recognize this portlight?
59
Hunter 450 CC Liberty Landing, Jersey City NJ
Yet another boatyard visit without me, TJ removed this fixed portlight and brought it home to inspect. Has anyone got this fixed portlight on their boat? Have you replaced it? Were you able to remove the lexan and replace it? We're in a pickle, all the fixed portlights are leaking and need repair or replacing. We've gone over the forum and not found anyone that has experience with these ports. Any suggestions? I'll call Hunter at some point but thought I'd try here first. Thanks in advance, Laurie
Dec 2, 2003
4,245
- - Seabeck WA
Laurie, are you looking for the OEM?
You realize that those windows are all made at the factory, right? There isn't much of a market for other manufacturers to ramp-up production except the builder. And if an outside shop made the components, they aren't likely to even have parts left over. Most owners make their own when it's time to replace. Hope that answers your question.
Jun 21, 2004
88
Hunter H31 Niagara Falls
its in the archives
Check the link below. It pertains to a hunter 31. Yours are the same overall shape as those on an H31, but I am unsure if the size is the same. If the frames are OK, the lexan can be had from any glass dealer. Replacing the frames is discussed in the link. Frame replacement is pricy.
May 22, 2004
121
Hunter h41 San Francisco
Select Pastics
I might suggest that you contact Select Plastics. They seem to know all about hatches and portlights.
