Jason Howard
All,I'm considering purchasing a Harken furler (unit 00a) on my Hunter 22, but I am a little worried about the installation, specifically the modification of the headstay (length). I am usually a die-hard-do-it-yourselfer, but cutting the stay has me a little worried. Harken advertisements boast that this unit fits over the existing headstay, but the manual I saw on their web site indicated that it might be necessary to shorten it.I contacted a local rigger who gave me a price of $1000 including the unit. That seems a little steep to me since the part is only $670. The rigger indicated that the system did in fact fit over the exisisting headstay without modification which leads me to believe that I should give it a go.Anyone install a small boat roller furling system? If so, would you do it again?Also, I hadn't properly considered the modifications that would need to be made to the 150 that I plan on using (most of the time). Sailmaker quotes are around $400. Does this sound high? Anyone have to cut the sail?
