Hi All,I've got my boat on the hard for the next 4 or 5 months to do lots of projects. She's a 1975 Pearson 10M and the hull is in very good condition - there are two blisters and they're smaller than a dime. I know those are too small to worry about.Since I won't have her out of the water for an extended time again for a few years, I'm wondering if I should add a barrier coat. Clearly the hull is still in good shape, and I want to keep it that way. On the other hand, I don't want to waste my time doing work that will provide little if any benefit.By the way, I'm also changing, and in some case relocating, all the thru-hulls and seacocks.So here's a few specific questions:1. Should I sand the remnants of the (sloughing) bottom paint off now, and let it dry out for the next few months until I get closer to splash time?2. How can I see if a barrier coat has already been applied? (Maybe that's why it's in good shape?)3. Is there generally any value in applying a barrier coat as preventative maintenance?Thanks for any help.Craig
