Do I need a New battery charger?
Dave Swanson
I have a 1989 Hunter 30. It has 2 group 24 gel cell batteries that were purchased in 1992 and 1995. Both batteries are used for house and starting loads. I am getting ready for a month long trip in Desolation Sound this summer and so I am trying to determine if I should replace the batteries. I took them to a local marine store where they did a load test and said that they appeared fine. Therefore, it appears that they do not need replaceemnt at this time. I have also been thinking about replacing the stock 8 amp RediAmp ferroresonant charger that came with the boat with a 3 stage charger. Has anyone done this with good results. The advice that I keep getting is to replace the charger, but with 7 and 10 year old gel cells apparently working just fine, I am having a hard time justifying the expense. I am also considering getting a combiner to avoid having to switch to "ALL" prior to charging them while motoring. Any advice or comments out there regarding battery replacement, charger upgrading, combiners or energy monitors?
Dec 2, 1999
15,184
Would not worry about the batteries.
Dave: I got 10+ years on my gels. I was using a Pro-Mariner charger that was similar to yours. I changed the charger about a year or so before I replaced the batteries. I was also amazed that I got that many years on the batteries with the 'wrong' charger type. If I were you I'd just leave everything as is, until you decide to upgrade your entire system. Then you should consider a charger like the Statpower or one of the other high quality smart chargers.
L
larry w.
Batteries
Dave; IMHO, you have what would be considered the bare minimum. If you run refridgeration, you won't be able to stay away from a plug-in charging source for very long. (I'm betting you have a really small alternator with an automotive-type regulator) Builders supply these kinds of system because they're inexpensive, but most knowledgeable owners upgrade to dedicated house banks, separage engine start battery, high-output alternators, smart chargers, etc. However, if you're a minimilist type, you might be able to get by with what you have.
