My Schumacher SS-210A or SE=210A (Manual is for both, not sure which.) isn’t one of the Ship N Shore ones you’ve been warning people about. It checked out as having no back leakage when off. It’s a dual 10 Amp charger and so now a single 20 Amp as I have it hooked up to my two battery bank. It has temperature compensation at the charger which is on the opposite side of the engine room from the batteries.
I picked up my new Deca Sea Mate AGM’s and had them first put them on the store’s charger so I could synchronize my Victron monitor with them at 100% SOC to start. When I made the final hook up, the Victon read 12.56 volts which seemed a bit low since I would have expected some surface charge. When I came back in the morning, it read 12.60 volts.
I plugged into AC today and turned on the charger. After doing it’s diagnostics, it turned on the LED indicating bulk charge and the Victron read 14.8 volts. That’s a bit high but it quickly started dropping back to 13.2 – 13.4.
Previous behavior with my old batteries near full charge has been to go quickly through its three stages to float over a period of only a couple minutes.
I looked up about 5 minutes later and was surprised to see 15.43 volts. The charger LED’s indicated it was on stage 2. The voltage went down a couple minutes later to mid 14’s and I figured it was doing some final diagnostic before switching to float.
A few minutes later it was back up to 15.46. After about 5 minutes of watching it wandering around close to that number and remaining in stage 2, I decided it was time to pull the plug and come home to write this.
As soon as I turned off the charger, the Victron went to 13.36. I turned on about 3.5 amps of lights to bleed off any surface charge and it dropped quickly and steadily to 12.66 over just a couple minutes. The Victron indicated 99.99% SOC.
I turned everything off and voltage came back up to 12.76 about 5 minutes later and 12.81 about 5 minutes after that.
Time to rip this thing out before I fry my expensive new AGM’s?
