I have water that is coming from a crack that is near the floor, under the sink in the galley. I can put my head in the door under the galley sink and directly below the left side of the door on the side of the wall nearest the floor there is a crack in the fiberglass. From that hole there is a leak that is slow. I want to dremmel the crack open a bit and see what is on the other side but i don't want to put a hole in the tank. I was looking at some pictures a guy posted and saw the ballast tank being installed at the factory. I noticed that the tank had a lower section that was separated from the bilge area by a trough. Since i just put the boat in the water i am wondering if, when i missed the hole with a hose, filling the tank if i inadvertantly spilled water into this area and filled it with water. If this is the case it maybe that that water is trying to find a way out of that area and found the crack in the fiberglass (liner?).
Also, Please let me know if the galley and floor is a liner that is installed on top of the ballast tank
Here is a link to the picture of the water ballast being installed at the factory.
http://hunter.sailboatowners.com/index.php?option=com_mtree&task=viewimage&img_id=6863&Itemid=222
