DIY telltale fail
CapnGL
Sep 22, 2016
146
MacGregor 26D COUR D ALENE
I did some searches and settled on sticky back vinyl.....so I made the telltales and stuck them on BUT they didn't stick. duct tape wouldn't stick....It is a UK sail. what will stick to this crinkly sail? It's pretty slick.
Thanks
Greg
Feb 8, 2014
1,300
Columbia 36 Muskegon
Old Timie Way: Yarn poked through the sail with a big needle, knot tied on either side.
Aug 28, 2006
578
Bavaria 35E seattle
I've bought nylon tell tales at Fisheries Supply and West Marine before. They seem to adhere fine with sticky discs that are part of the tell tale.
Mar 26, 2011
3,774
Corsair F-24 MK I Deale, MD
a. Wool yarn is classic. You can keep the needle hole small by using a smaller needle and loop of upholstery thread to pull the yarn through.
b. On the main all you need is luff telltales, which you may be able to tie onto batten pockets.
c. Bainbridge rip-stop sail repair tape is what the commercial ribbons telltales use. Cut it in a circle, and run the telltale through a slit near the center (I place them slightly aft of center--seems stronger) of the tape.
Tip: Put the tell tales lower on one side so that you can always tell which are which, no matter what the lighting. No need to use red and green.
Check out my books for lots of tips for newby sailors. Much of it is NOT in the other books, particularly the money-saving tips.
Likes: CapnGL
Joe
Jun 1, 2004
8,237
A package of seven pair only costs $5.79 Even comes with instructions on how to use them!
Likes: CapnGL
