Brian
I have a 26' Annapolis in need of a wind vane and VHF antenna, and am considering dropping the mast myself. Here's the plan... Remove the boom, make a 16' rig with 2x4's and fasten it to the mast low (below where the boom went), loosen the other stays a little, hook the backstay to the other end of the rig to drop it forward, and putting a line from the aft cleats to the aft end of the rig to control the drop. My mast is unhinged, so I'd probably need a line from the front cleat to the bottom of the mast to keep it from moving aft in the process. I don't think the mast weighs more than about 200lbs--is this a good guess? Any further guidance will be appreciated... Thanks!
