small sloop
Hi
Thanks for the answer on the diameter of the stern pupit tubing (1 inch).
Now I need to know the approximate distance between the top stern pulpit rail and the rail beneath it. I just need an approximate distance so I can show up at the boat with a piece of tubing long enough( I will cut it to size) to connect two TAKE-APART RAIL FITTING - 90 DEG. TEE 1in (from binnacle supply) . The tube will be placed vertically between the two existing tubes to steady a mount to carry my 2hp Honda OB.
It's a long story but this dimension should help.
Thanks
SmallSloop
Thanks
SmallSloop
