Displaying Dinghy Bow Numbers?
Jun 7, 2016
315
Catalina C30 Warwick, RI
I have the federal documentation submitted for our sailboat but I still need to state register our dinghy. It is going to be registered in Rhode Island and my question is what do you all do for displaying the bow numbers on a dinghy? My primary concern is the stickers won't stay on especially after deflating it. The previous owner never displayed them and just always kept the current sticker and registration in a waterproof case in the dinghy in case he got stopped. Is this a normal/acceptable practice?
The numbers are painted on where they are supposed to be, the bow. The stickers showing the annual/biannual registration are on the transom, one inside and one outside. Never been stopped. Probably not legal, figure I'll try to talk my way out of a ticket if I ever get stopped. Better to have the stickers improperly displayed than to be unregistered. That's my story and I'm sticking to it.
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
I use these: Boat Number Registration Plates for Inflatable Boats
I ordered without the space for the state sticker and put the sticker on the transom. I had the plastic plates attached to the dink with zip ties but someone stole the plate with the annual sticker. Tried painting them on but the Florida sun faded them off too quickly.
Feb 10, 2004
4,183
Hunter 40.5 Warwick, RI
I have painted and repainted every couple of years. Gets old. So I went for the Boat number plates with the decal space. I haven't had good luck with them either. Deflation and roll-up tends to lift the edges. And I had a set that discolored badly that they replaced. The self-stick version is really bad for sticking and I followed all the instructions to a "T". So I am going to try one more time with a hypalon 2-part glue for the number plates. If that fails again, I will skip the number display and just carry the registration papers and put the decal on the transom.
Bottom line- I have no good solution. YMMV.
Ted
Jan 26, 2005
1,272
I made plaques out of weather resistant VHMW Polyethylene which doesn't yellow, is strong and flexible. The registration numbers and stickers are applied to them. Each plaque is attached to my inflatable with two stainless steel shackles. They can't be removed without using a tool but little can be done if someone really wants to steal them. I remove the plaques before storing the dink.
capta
Jun 4, 2009
5,006
Our last Zodiac had the RI numbers stenciled on either side of the front and they were quite legible for over 8 years, uncovered and unprotected in the Caribbean tropical sun, 24/7/365. I didn't put them on, but they seemed to be a regular enamel paint, probably spray.
After 40 odd years of owning inflatables (never a RIB) I have found that to paint or glue one, you must sand the sheen off the material and make absolutely positive that the areas to be worked on are perfectly clean, and this means of fingerprints as well. We wash the area with acetone before applying the paint or epoxy glue, and we get 4 years or more from glue jobs (mostly the lifting tangs) and the paint gets twice that.
Since we've never had a breakdown of the material or a leak due to construction (like at the seams), I can only assume it is because we only buy the best quality inflatables, French built Zodiacs or in the old days, English built Avons. You can really see the difference in quality when the Zodiac Mark II Classic is sitting at a dinghy dock surrounded by Highfields, Achilles, WM et al.
Nov 26, 2008
1,970
Endeavour 42 Cruisin
I use a permanent marker for the numbers, similar to a sharpie but a bigger tip and better ink. Fades after about a year but I've gone 2 years with faded but legible numbers.
My Fl reg sticker has no problem staying stuck on the bow.
Jun 14, 2010
2,408
leave it inflated for the season
I leave it inflated, but it does go through some big variations and becomes partially deflated over the winter. Those letters have thinner vinyl than others I've used and that might be helpful.
ToddS
Sep 11, 2017
248
Beneteau 373 Cape Cod
Yup... I use sharpie as well (again, not "Sharpie brand... I think the brand is B.A.M. if I recall)... takes 3 minutes, and lasts for months... roughly one summer for me... no chance of peeling. Easy to write over it to darken when/if it fades. Cheap, easy, reliable. The registration sticker itself, I put on the transom even though I know that's technically against the rules... I asked a Harbor Master once about what to do about peeling stickers on inflatables, and he recommended the transom thing... while they could TECHNICALLY cite me for not having it at the bow, I've mentioned it to a few harbormasters and coast guard guys in the past and before I even get to the end of my sentence, they say "yeah, yeah, that's totally fine... happens all the time". The super-wide permanent marker tip is the key to writing it neatly... don't try to draw the numbers with a normal/large sharpie... it has to be EXTRA-wide to look good.
May 25, 2012
4,338
me too. sharpie, stickers on transom
it is proof you payed your money. the key to what they want
Dec 25, 2000
5,950
Different state here, but I have a dinghy for our boat with a five horsepower outboard and for the way we use it, no need to have it registered. What is it about your location, or intended use, that requires you to purchase numbers in the first place? No joke or sarcasm intended.
Most states, including Washington require any powered vessel to have registration numbers.
  • Tenders 10 HP or less used for direct transportation between a registered vessel and the shore and for no other purpose. The tender must display the number of the registered vessel followed by the suffix "1".
