tonnage....(useless, but interesting)
from Ocean Navigator.....link is to full storyGross tonnageKnowing the deadweight tonnage of a vessel is one method of measuring it cargo-carrying capacity. However, gross tonnage is almost always required. Gross tonnage is the interior volume of a vessel as measured in units of 100 cubic feet. (Each such unit equals a gross ton). Gross tonnage is a measure of all enclosed interior space of a vessel, including all compartments, machinery spaces and most enclosed deckhouses. It has little to do with the actual weight of a vessel.Anyone handy with a tape measure could easily measure the interior volume of a compartment. Indeed, if it comes right down to it, Coast Guard officials or surveyors from organizations like the American Bureau of Shipping are fully prepared to do just that. Short of physically measuring each compartment, however, a surveyor might also determine gross tonnage by taking measures of length, breadth and depth from each station of a vessel as shown on its design plans and doing his calculations by section.There is an even easier way to compute gross tonnage, however, using the simple formula:where: length is the length overall, not including bowsprits, boomkins, figureheads, etc.; breadth is a vessel's maximum beam; and depth is the vertical distance from gunwale to bottom of keel.This is the formula used by Coast Guard documentation offices to calculate gross tonnages for yacht owners who do not, typically, know this measure of their vessels. This is a thumbnail technique for determining gross tonnage but it is generally accepted as accurate enough for most record-keeping purposes.Here are some more examples of gross tonnage. The 52-foot Hinckley sailboat mentioned above measures about 45 gross tons. A typical 35-foot light displacement fiberglass sailboat measures in at 12 to 15 tons. A Mason 44 has a gross tonnage of 36.85. A Nordhavn 62 trawler yacht has a gross tonnage of 101.9. The 125-foot LOA wooden schooner Spirit of Massachusetts is rated at about 90 tons.The somewhat simplistic formula for calculating gross tonnage is sometimes used by yacht designers and Coast Guard inspectors to get a preliminary estimate of a vessel's gross tonnage, often with a more formal measurement process to follow. A preliminary measure of tonnage, however, can be useful in determining how a vessel will fall into various systems of regulations, rules, and requirements for crewing, licensing, safety equipment, and inspections. In another situation, a yacht designer may wish to comply with his client's wish that a vessel being designed and built not exceed, say, 100 gross tons.
