Dishwasher detergent
515
Hunter 320 Williamsburg
Peggie, as a longtime disciple of yours, I know you frown on putting anything in the waste tank unnecessarily. But what about the use of no-suds dishwasher liquid to slosh off the debris stuck to the inside of the tank?
Thanks.
Dec 2, 1997
8,954
- - LIttle Rock
DishWASHER detergent is a no-no...but dishwashing liquid is ok
So what if it sudses a little...a few bubbles out the vent won't hurt anything. :)
I'm guessing that you want to clean out the tank ahead of winterizing. So first, pump out the tank and THOROUGHLY rinse it out to get rid of any sludge before you "clean" the tank walls.
If you're gonna use enough Dawn or something similar to do any good, you'll prob'ly need a whole bottle of it in a tank full of water...go sailing and tack a lot...then let it stand at least overnight. Pump out (or dump offshore) and thoroughly rinse again...then winterize.
This should be as often as you need to do it.
