ok, i got all the motor mounts free and disconnected all of the hoses, wiring, etc. all thats left is the shaft. I attached a pic. i've never done this before, but it seems pretty straightforward. I just want to make sure. there are 4 bolts on the forward side and 4 bolts on the aft side of the coupling. and a plastic spacer in the middle. which set of bolts do i need to remove? or both sets? thanks.
b
b
