Disappointed in Beneteau
Dr. D
Nov 3, 2018
288
Beneteau Oceanis 35.1 Herrington Harbour North
This only applies to the Oceanis 35.1 and 35. I'm not sure which years besides my 2018 35.1.
To reduce cost, Beneteau installed "Low Friction Front" boom end fittings, or "Friction" fittings. These fittings do not have sheaves (see attached). On the outboard boom end fitting, there is a central island for the topping lift to attach. In the middle of the space on either side of the island is a shoulder, thus defining four tracks. The problem is the outhaul line on the 35.1 has a diameter about the same as the width of the tracks. So when you pull on the outhaul line, as it makes the 180 degree turn, it flattens a bit and rubs against the sides of the track besides the inner aspect; this creates a ton of friction. You need to use a winch to unfurl the main sail. OK, maybe if you are a weight lifter you wouldn't need the winch. There is a video from Neil Pryde showing how to use a furling mast and main on a Oceanis 38 (normal end fitting). The demonstrator unfurls the sail by hand; at one point with one hand.
I put up with that nonsense for too long. I had a rigger replace the "Max Friction" outboard boom end fitting with a normal fitting with sheaves. The difference: I can unfurl the main sail by pulling the outhaul line with my hands. Same goes for furling. It takes a bit of effort, but I think that is due to the inboard boom end fitting being a simple ledge with no sheaves. I might replace that one, too, at some point, though this setup seems sufficient.
How many dollars did Beneteau save? The claim by Sparcraft that the "Friction" fittings reduce maintenance seems hollow.
Likes: sail sfbay
That is disappointing. On the previous generation they used US Spars masts and booms with traditional sheaves. Certainly wouldn’t want any more friction than absolutely necessary in that system.
Mar 20, 2016
595
Beneteau 351 WYC Whitby
Seems more a Sparcraft issue then a Beneteau issue . Maybe they should have stayed with zspar or Selden
I have my doubts that Beneteau spec those low friction fittings , sheaves on US spar (zspar) are like 6.00
Dr. D
Nov 3, 2018
288
For the boat production, Beneteau is the prime contractor while Sparcraft is the subcontractor. The prime has the responsibility to review the work, or suggestion, of the sub and accept or reject it. For the 35, Beneteau should have rejected the suggestion of using the sheave-less end fitting. I'm not saying it doesn't work on smaller boats with less sail area and thinner outhaul lines.
Jun 29, 2010
1,287
Maybe you should talk to Beneteau then..... Hindsight being 20/20.
Likes: Dr. D
Dr. D
Nov 3, 2018
288
I contacted the dealership where I bought the boat and waiting on a reply from them.
