dirty shore power cord
Mar 15, 2011
17
Catalina 30 mkI Port Clinton, Ohio
Any suggestions on how to clean and seal a shore power cord? I have two that are supposed to be yellow...right now they look like the color of rotten bananas.
Thanks
Mar 20, 2012
3,983
Thanks
It may be time to replace them... but if I wanted to clean mine, I would first pull them thru a rag saturated with wd40 several times, then switch to a rag saturated with laquer thinner... if that doesnt turn them yellowish again, its hopeless...
If they are old cords and have been sunbaked, they will never again be bright yellow...
Oct 2, 2008
3,810
Pearson/ 530 Strafford, NH
Nov 6, 2006
10,050
I think West Marine has 'em on sale for a couple or three days right now
I used the two part cleaner kit. A real PITA with so-so results. I don't think the clean lasted. Some people cover them which seems to be a more realistic solution.
Nov 6, 2006
10,050
When ya do get a new one or clean that one, slather it really well with SPF 50 sunscreen .. Will tend to keep the plasticizer in the PVC cover and prevent sun damage.. about once a month is sufficient..
caguy
Sep 22, 2006
4,004
Carb cleaner or Acetone. Chief
Plus 1 on the Acetone. I just cleaned mine last weekend. They looked just like you described them. They were really grody looking. I was concerned that the acetone would leave them sticky soft. I have cleaned old fenders with acetone that were soft for about a week. I used the cord on Tuesday and it was like new. I found the easiest way was to put tension on the cord by stepping on it and pulling with the left hand while wiping with a rag with the right.
Nov 26, 2012
2,315
Catalina 250 Bodega Bay CA
You just can't stay on the plastic too long with Acetone since it is the curing agent for most plastics. It will remove the black printing on plastic pipe and make it look much better as well. Chief
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
I'm gonna try the acetone then encase it in pool noodles to protect against the sun. The denser stuff used for pipe insulation makes good chafe protection for dock lines.
Jan 11, 2012
44
Ontario Yachts 38 4 Trent Port
By the time the jacket gets grody, the contacts are usually worn and the cord should be replaced anyway.
Bad contacts in a shore power cord, contribute to heat and fire.
Starting a fire on your boat to save a few bucks is a fools game.
Don't check your shore power cords for how ugly the jacket is looking, check them for the condition of the contacts. If worn, replace, ugly jacket or not.
May 10, 2008
392
Catalina 355 Boston
Another way to clean cords is a 5 gallon bucket filled with Hot water and Oxyclean. Let soak for an hour, occasionally agitating the water. Keep the ends of the cord hanging outside of the bucket. Works very well if you don't want to go the Acetone route.
