dingy line
A
alans
hi, getting dingy ready for launching. my 10 ft. avon has a bridle set-up. how much line should i purchase for towing it. thanks alan
Dec 25, 2000
6,067
Hi Alan, I carry our dink on the transom...
step rather than tow. Much safer and less drag on the boat. I do have 50 feet of rope with a mushroom anchor that I use for the painter when I go ashore. Terry
Deadline
50 feet
Ask someone on your dock for their advice. Typically 50 feet should do it. Be sure to tie it in a V to two aft cleats. Be sure to use polypropene (yellow) line. It floats, which precludes the line fouling the prop.
Jun 16, 2005
476
- - long beach, CA
If you're going to tow it
in the ocean, adjust it so it's on the face of the second wave behind you, and be sure to put a rubber shock absorber in the tow line somewhere.
Dec 25, 2000
6,067
Hi Alan, just as a follow-up note...
some ocean going cruisers will advise you to carry the dink on deck, deflated and tied down usually forward of the mast. See link regarding how we carry our dink. Terry
paulj
Mar 16, 2007
1,361
Catalina 310 Anacortes,Wa
alans
Deadline has mentioned a good starting point. You will learn the rest as you continue to sail...if the sailboat slows down turn around.... paulj
