Carry your Dinghy
D.: We have an inflatable dinghy and use it often. We use it to go to restaurants when our boat is at anchor. It's an inflatable Seyvlor, which is 9'2" long, and came with fittings attached to it so that it can take a motor bracket. I made the motor bracket for ours, but Seyvlor sells a bracket. We use a 2 HP motor on our dinghy, and my 2 sons really enjoy using it. This dinghy is light weight, and when it is deflated, we just stuff it into a sail bag, and put it into the sail compartment with the sails. We blow it up with a battery powered inflator for an air matress, that does the job in a few minutes, but we also have a hand pump that we use to make it firmer than the battery pump does. I do recommend an inflatable, because from my experience, a C-22 can't pull a dinghy without serious loss of sailing preformance. When we pull the dinghy described above, the pull on the rope is unbelievable. I have also pulled a sailboat that I previously had, and again the pull on the rope was very great. Also, the dinghy towed behind a C-22 can fill with water, and from experience I can tell you that this can ruin your day. We don't consider our dinghy a safety item. We sail on the Chesapeake, and the biggest waves that we have sailed in have been about 4 feet. I have attached a link to my son's website. At the bottom of the webpage, you can see a photo of the dinghy that I am talking about. We carry our 2 hp motor on a teak block that is mounted on the starboard end of the traveler. I know, it takes away about 3 inches of the travler, but it's worth it, and hasn't seemed to slow the boat down at all. I think that our solution to the dinghy issue has been a good one for us. We did use it extensively on the National cruise. There is a place to click on Danny's website to see photos from that cruise. We received many positive comments about our dinghy from the other sailors on the cruise. Aldo
