Dingy ,AKA Submarine
I pulled my 12 foot POS, I mean Quicksilverto Dry tort. south of Florida and thru the Bahamas from Norfolk last year , I only had one problem, It went under water 3 times in the Neuse river, First time I lost both seats and fuel tank and , if I had the motor on Im sure that would have been another problem.I tow with the plug out so it drained, The tow rings on front of the dink bent, one pulled out, I had to keep going due to the weather.After I fixed the tow rings I towed it the rest of my trip, I would , and have towed any time in just about any weather condidtion, but never with the motor on. I also do not keep the new seats in it or anything else i want to keep in it. You know it really is not a problem at the fuel docks or going into slips if you watch the painter length and shorten it up before you get near the dock, plan ahead . I also can lift it up over the life lines on the bow with the extra jib halyard. Then I lash it on deck with some clips installed on the bow. If I want to get it out of the water .Cause it slows my boat down when I tow it.
