Dinghy Tow - anyone use one?
May 23, 2012
3
Hunter 30 Midland, Ontario, Canada
I am considering getting a Dinghy Tow. I just heard about it and it looks like it might be suitable for my needs.
My boat is a '89 Hunter 30' which has lockers that double as seats outboard the walk-through transom. I am concerned that the system might interfere with access to the lockers or the use of the seats (which are one of the best places in the world to enjoy a sunset whisky and cigar!)
I don't think that my dinghy and outboard will present a problem with regards to weight etc. My dinghy is a Highfield Ul260 - which is very light (68 lb) - and carries a 2 hp - 4-stroke Honda.
I tow my dinghy on a short line with a snubber with the engine mounted on the pushpit. I don't have enough room to carry the dinghy on my foredeck as it prevents me from accessing my anchor locker.
We travel with a dog and are using the dinghy frequently so de-flating and stowing aren't a great option. The rigid hull would mean that the de-flated dinghy would still need to be stored on the foredeck.
One of the things that appeals to me about the Dinghy Tow system is how it would enable me to store my dinghy at the marina, so that I don't have to bail it out after every rain.
I'm waiting for a quote back from the supplier but I suspect the system will be a lot more economical than davits. I think my boat is too small for davits anyway and I don't like the loss of 360 visibility that davits cause.
Anyway, if anyone has any experience with this system, please let me know what you think of it.
Interesting idea. How about worst case issues?
Your out, the dingy is in it's stored position and a squall comes heading for you. What would you do to secure the dinghy without it ripping the transom off the boat? In the up - stored - position looks like the dinghy could serve as a brake sail to slow the boat. A Spinnaker in reverse. If you sail in protected waters and comfortable weather conditions looks like it could be an answer to the problem.
As a friend said, "Your Boat Your decision".
Gunni
Mar 16, 2010
5,937
Have you considered a towing bridle with floating propylene tow line? I have towed dinks with a proper tow system through just about everything. And there have been times when boarding waves would have made a mess of that rig you are looking at.
Sailm8
Feb 21, 2008
1,750
Hunter 29.5 Punta Gorda
I have never tried this but someone on this forum tows their dink backwards with it pulled up and resting on the 2 lockers on either side of the swim platform. Seems like it would reduce drag a little bit. They said if it looks like the weather is turning, they unhook and tow regular.
Gunni
Mar 16, 2010
5,937
With a bridle on the dink, and a rigged bridle on the stern of the boat (stern cleat to stern cleat) you can position the dink anywhere you want it - close in for control, or way back to keep it from riding up your stern:
The $150 USD solution.
