Barry Lenoble
Hello,I recently acquired an old worn out fiberglass 'Sumner boat' dinghy. The fiberglass hull seems to be OK, but the wood gunwale is worn out. I have no experience working on stuff like this. I would like to repair the dink for use in rowing to my mooring. I was thinking of using 1" wide by 1/4" thick wood strips to replace the gunwale. One strip mounted inside the fiberglass edge and another on the ouside, screwed together. Will that work? Will I need to put another wood strip on top? Is there a better way to repair this boat, or should I just bite the bullet and buy a new one?I figure I will also learn some fiberglass, epoxy, sanding, and painting skills that will come in handy later.Thanks,Barry
