Quite simple.
Steve:I did this to our Caribe. It has been a couple of years ago.As I remember, to find the leak I used some soapy water to find the leak. Then I marked the area with a marker (didn't want to try to find it again). Clean and dry off the area. Then I hook a piece of sand paper and sanded the area to be patched (make the sanded area slightly larger than the patch). Followed the direction on the glue can and it was done. As I remember the glue is like contact cement, so you apply glue to both pieces and let them dry and stick them together.Are you sure that you do not have a leaking valve? These valve sometimes get sand in them and leak. I'd remove all of your valves and wash them out before you get started looking for a fabric leak.
