8 ft 6 in Zodiac
Hi, Gail. We purchased an 8 ft. 6 in. Zodiac inflatable for our H340 with foredeck storage as one of the selection criteria. We measured before buying and that model just fit on the foredeck; anything bigger won't fit. It did not interfere with the headsail, and there was just enough room to squeeze by to the anchor locker if we needed to. The 8 ft. 6 in. size we have found to be OK for 3 people, or 2 people and a dog, and that has worked for us; if you want/need to carry more, you need to think bigger. But after all that, in two seasons we have put the dink up on the foredeck only once; the very first sail to home harbor after delivery; ever since then we have towed. If we need to make this decision again, foredeck storage might not be a criteria. Think about it.Other issues. We got a model with an inflatable high-pressure floor. The HP floor is very rigid and secure, and we are so far very pleased with that. It is a 'roll-up' model, and deflating/carrying/storing is very easy. We got a straight PVC-based model instead of Hypalon. Hypalon is supposed to stand up to sun and weathering better, but it is significantly more expensive. With our 6-month New England season we decided to try PVC; if you sail in an area with a longer season and more intense sun you may want to go Hypalon. We have a towing bridle which we really like.The motor. We have a 4 HP, 4-stroke Yamaha. GREAT motor, but weight is an issue; it's a heavy motor to lift back-and-forth between the dink and the rail mount on the boat. Along with horsepower and 4-stroke versus 2-stroke, consider weight and handling. We are currently considering a Forespar collapsible motor lift.Good luck!Carl and JuleH340, s/v 'Syzygy'
