I've had Torqeedo 1.5hp since 2016. I'm not sure of the model number, but I think it's the same. I use it to push a Zodiac Wave 10'2" 90lbs. I've never had an issue with it. It always starts. I've used it with four adults in the boat. I would never own a gas outboard again. The Pros: Light weight, only weighs 35 lbs including the battery. No gas, oil, turn the handle and it runs. Built in GPS tells you how far you can travel with the amount of charge left and the speed setting. Using it at about 50-60% the battery would for a long time before charging.
Cons: You can't go fast if you want to battery to last. The plastic covers break easily. I've chipped mine a couple of time.
I definitely would buy another one if needed. Like I said, if you want to go fast, you will need to recharge more often. The only other thing is that we get a lot of weeds around our dingy dock and the prop would get easily jammed with weeds. So I would have to row out to deeper water to get free of the weeds. Feel free to contact me if you have more questions.
