I'm planning on making my own davits using aluminum flat bar stock, either 4" wide X 1/2" thick or 3 &1/4" wide X 3/4" thick. It will be to support a 10' dinghy and a 9.9 hp motor, plus my solar panels, total weight about 350 lbs. I'd prefer to leave the motor attached but may mount a pushpit rail bracket to support it. My question is this: The foot plate for the uprights, that I need to support all this weight on the transom, would you use 5" X 5" outer plates mated to larger backing plates inside the aft lazarette, drilled through the transom just below the rear rub strip, or make a U shaped bracket that wraps upside down around the top of the coaming at the extreme aft of the cockpit, with an inner spacer plate inside the lazarette as a backing plate? The easiest way is just the 5X5s but I want this to last. Fresh water cruising only, with a planned trip from Midland Ontario to Chicago via the Great Lakes. Any advice and pictures of your homemade remedy will be appreciated. Thanks. Norm
