Mike
Last summer one of the floor boards in my Zodiak became water soaked. I have had water standing in the dinghy many times for many days at a time and never damaged the boards. The floor is the multi-section type with heavy plastic strips which hold the boards in place. The boards are about a quarter inch thick and appear to be made of some kind of pressed board which I assumed (wrongly) would be fully water proof. My question is: if I repair this board with a coat of fiberglass matt and resin will it be too thick to fit in the dinghy and will one coat of matt and resin be enough to protect it from further water damage? Also can I coat it with some sort of resin without the fiberglass matt to seal it from water damage?I am pretty sure I can go to Zodiak for a direct replacement but I'll bet it'll cost an arm and a leg. I suppose I could make one out of quarter inch polyethylene sheet but it wouldn't match the rest of the boards. Mike
