dinette cushions
K
Kleetey
We just purchased a 33.5 Hunter and have no clue as to how to convert the dinette into a sleeping area. We tried moving the cushions around. Is there an insert? Or, did we just not do it right? At the risk of sounding stupid, could someone tell us? Thanks
Jon Geniesse
Another Bed for Grandma
I presume it is the same as my 35.5 (I may be wrong). First, remove all the cushions, lower the table into position by turning the locking key inside the table compartment to loosen the compression, and push the table down into position (this presumes it has the same counter balance mechanism as the 35.5). You can than replace the cushions, and insert the last cushion (which is mounted against the bulkhead in the aft berth) into place, it fits around the compression post. Hope this helps. Jon
