Dimension of Propeller Hunter 34
Rigoletito
Could you confirm the measurements of the propeller of a Hunter 34 Built in 1984 ? Thanks in advance
Pete
15x15x1
The spec on HOW show the prop is 15x15x1 two blade as original equipment. Might want to try E BAY in there boat equipment section also.
Jun 3, 2004
890
Hunter 34 Toronto, Ontario Canada
Believe that is right for Yanmar 3GMF
I beleive 15X15 is right for the Yanmar. My late 83 H34 has the 15X12 which I think was the prop for the Westerbeke. Obviously had some props left in stock. Even so, I do 6.8 at 2600 in reasonable wind and waves. I had it retipped with "non Slip" tips a couple of years ago- no real diff in top speed, bit straighter backing
Oct 14, 2005
2,191
Prop size
I have the original factory supplied two blade prop, 15x12 RH 1" shaft, on my '83 H34, hull #113, with 3GM30F Yanmar power.
Rick D
Jun 14, 2008
7,203
Possible Prop Source
Rigoletito, these guys have a whole room full of used props if you have trouble getting one locally. They do ship to Mexico. MINNEY'S YACHT SURPLUS 1500 Newport Blvd. Costa Mesa, Calif. 92627 PHONE 949-548-4192 FAX 949-548-1075 Link submitted by author E-mail sales@minneysyachtsurplus.com
Mar 22, 2005
20
Hunter 34 San Carlos Sonora Mexico
Available prop for Hunter 34 ?
Richard Would you know if their are Prpos available Thanks
Jun 3, 2004
890
Not sure what you are asking
Not sure what you are asking Rigoletito- lot of different sources for props, all sizes, 2 blade is pretty easy to find
