Down to the boat last night for some cleaning for an upcoming trip in a few weeks and decided to run the engine for a bit as I have not cranked it in about 4 weeks. Cranked right up but imediately noticed NO water coming out of exhaust port on the stern. Shut it down rechecked seacock and restarted with same results. Blocked in seacock and checked line from it to strainer(clear) pulled raw water pump apart and replaced impeller (old one looked good, no missing pieces or deformity) checked line from raw water pump to heat exchanger(clear) pulled heat exchanger ends (tubes clear)
I'm guessing the only thing left to check is the mixing elbow. Seemed to be running fine 4 weeks ago. My question is could this elbow get clogged in just 4 weeks of non use?
And 4 weeks ago i only ran long enough to get from hurricane tie out point back 50 yards to slip. I am hoping to go down this evening after work and try to removed the mixing elbow to look see. Any ideas anybody???? Thanks in advance....frank
