I have a 25 gallon diesel tank. I received different recommendations concerning what is best for my tank. Some say to keep it topped off in order to keep condensation out. Some say to not top it off in order to burn the fuel up before adding fresh fuel so that the fuel will not sit in the tank as long. Some say to use an additive in the tank for fungus and some say not to because it will create debris from the dead fungus. Some say to add a water absorber to the tank. Some say that you should not top off the tank but, that you should not let the level drop below 1/3 because when the boat heals if the engine is on that air may go through the fuel line. Some say to be sure and run the engine on a regular basis(in the slip if I need to) Any comments will be welcome. At this point, I beleive, that I should put the water absorber and the fungus killer in a full tank and keep the tank relatively full but not always topped off and monitor the fuel water separator and drain off any water and change the filter if needed.
