Diesel smell
156
Hunter H33C Quincy, MA
When I go to step on the boat from the dock, I get the smell of diesel; when I go down below I don't smell diesel, just the moth balls the PO left behind. Any ideas?
Ed A
Sep 27, 2008
333
Hunter 37c Tampa
this one sounds easy. you got a neighbor with diesel in his bilge and the pump is doing a bp job in the marina. look for a sheen on the water, work the wind and current and you will figure it out.
could be an innocent error or a more serious problem.
play detective and get the dock master to heip you out. The owner may not even know its happening.
BobM
Jun 10, 2004
3,269
S2 9.2A Winthrop, MA
Pinhole leak in your fuel tank? Fuel odor from your tank vent? After a few minutes aboard you probably can't smell it anymore. The moth balls below will pretty much wipe out your ability to smell anything below. I personally would remove them.
Jun 7, 2007
515
Hunter 320 Williamsburg
Check the fuel sending unit plate. On my H29.5 the screws inexplicably came loose and fuel splashed around indefinitely. The diesel wound up in the "secret bilge," a ridiculous gully fully aft of the boat. It took a bucket of kitty litter to sop up and a contortionist (that would be me) to vacuum it out.
Jun 10, 2004
135
Hunter 30_74-83 Shelburne
Fuel sending unit is the fuel tank level sensor that's hanging in a fuel tank that has a remote reading fuel gage and has a tank penetration that Deadline says he had trouble with. You may or may not have one, my 76 h30 does not have one but what you are basically looking for is any opening in your fuel tank or tubing that will let a tiny amount of liquid diesel to escape- as Deadline pointed out, even normally dry openings that are not tightly sealed can let fuel splash out and you'd never know it unless you got right down there and looked, giggled, sniffed and touched. Empty the cockpit locker, move the companionway ladder out of the way and clean everything you can see and reach and rig a drop light or two above your motor/ fuel tank (cords away from belts) get a big bright flash light and run your motor and look for drips or wet spots to form. Good luck.
