Diesel fuel leaks, smells
My first fuel leak was at the top of the fine filter mounted high on the forward face of the engine. This was stopped by replacing the copper ring under the bleed screw.The second leak is at the manual fuel lift pump on the starboard side of the engine. The banjo fitting was not tight. However, tightening the bolt did not stop the leak. It appears that the small bolts holding the two halves of this pump need tightening. How can I get the Phillips screwdriver required to do this operation to the right place? "There ain't no workin' room!"Any ideas? The smell is controlled by placing a piece of the oil-absorbant matting under the engine, but there ought to be a way of having zero fuel leaks.
