I would not try to start your boat
with the old fuel in the tank. To me, it just wouldn't be worth it. Get rid of all the old fuel the best way you can. Either call a mobil fuel polisher and just have him suck the old stuff out (NOT polish it and return it to the tank) and see if he'll get rid of it for you. Or, unscrew the fuel guage on top of the tank and use a fuel rated hand pump to suck out the old fuel. Most every county has a toxic waste disposal where you can legally get rid of the fuel. If you live in or near Fairfax county, where I live, I can give you their address here. Once you have all the old fuel out, change the primary and secondary filters. Since you are selling you boat, just add 3-4 gallons of fresh fuel, bleed the system, and then flip the two decompression levers. With the fuel cutoff pulled out, crank the engine for a few seconds (with that new battery) a couple of times. This will put some lubricating fuel into the cylinders. Once the boat goes into the water, remember to flip the decomp levers back, open the raw water seacock, push in the fuel cutoff cable -- and crank the engine to a start. If the engine is going to be started out of the water on the hard, connect a length of hose from the water strainer to a 5 gal bucket full of fresh water and then try to start the engine. (Do not try to hook a water hose to the raw water strainer -- use a bucket). The engine will suck up the 5 gal of water quickly so be prepared to either add more water or shut it down. If there was nothing wrong with your engine when you last used the boat, it should start right up. If your raw water pump impeller is a couple of years old, either open the pump and check it or just replace it (and the gasket). Good luck with this.
