diesel lub questions
321
catalina 25, 30 montauk / manhattan
diesel lube questions
first time with a diesel (universal 18HP).
checking lubricants:
- oil low and added
- trans empty; not sure where the fill line is on dipstick. there is 1 at 1/8" from bottom then nothing until the top?
- coolant empty. manual instructs 50/50 mixture. being new thought i'd make sure to get the correct one so went ahead and the sales person at west marine. he was looking through and really wasn't sure since the one they have suggests full strength.
thanks
Catalina 320 Dana Point
oil low and added- OK, keep an eye on the level, ideally you shouldn't need to add oil between changes. Shell Rotella & Chevron Delos are the 2 "old School" diesel oils, but many oils certified for diesels currently.
There is usually only one mark, maybe 1/2" from the end and you don't screw the stick in to check, very small capacities, maybe 1/2 pint total.
Coolant used to be diluted 50/50 many now come premixed and ready to add, can't help you there except try to use the same color you have now (probably).
Oct 6, 2009
129
Newport Newport 28 MKII Jacksonville, FL
If you have the Universal M-18, it is 14hp, not 18hp. Not sure why they labled them this way. Also, the trans dipstick was too short by 5/8"(not the correct one) on my M18. Lots of trans fluid coming out of the dipstick vent hole from over-filling. Got the correct one and problem solved. It's a great engine, very low maint.
May 21, 2006
321
re coolant, i'll review the manual tonight however:
- there was an expansion coolant tank installed. only info the PO could give me was to make sure to add coolant into the expansion tank not directly to the engine. picture worth a thousand words however..
in the cockpit storage locker, there is a plastic tank mounted on the aft wall with fill line. assuming this is the expansion tank and will add the coolant there. however there is a metal tank on the bottom just aft of the water heater. Is this perhaps the original coolant tank and the plastic is the new one? not sure how this works.
thanks
