I worded it badly, I will rephrase my comment
The amount of total fuel coming from the tank to the engine, only a small percentage gets burned as fuel in the chamber. Fuel coming back out can be a very big percentage of what went into the engine because not so much fuel is burned; instead, it’s used for lubrication near the injectors, which are not lubricated by the lube oil. If you eliminated this extra diesel fuel, you engine will die.Yes, diesel is a fuel, but it is also an oil. Compared to gasoline, which is not a oil, and is only a fuel. Think about the history of diesel engines, and when it was designed, and what it was designed to burn as fuel. It burned "oil", as in poorly refined oil of those days, plus corn oil, nut oil, motor oil, lub oil, and french fry oil from McD. At that time, they hadn't even refined gasoline yet. What do you think biodiesel is?Now, biodiesel can attack a modern diesel engine's other parts, such as seals, but you can probably burn B10 with little problems. The very old diesel engines had internal parts that were not easily damaged by bio-oil.
