I bought a Hunter Legend 45 with a Yanmar 4JHTE about 2 years ago. There was a lot of diesel fuel in the crankcase. Asked around and was told fuel pump bad (leaking diaphram). I replaced it and everything was fine - until this past week. Fuel back in the crankcase. I called Yanmar dealer and they just say bring it in. Has anyone had recurrent fuel pump problems? Are there new additives in the fuel that eat diaphrams now at alarming rates? Could there be another path that so much fuel ends up in the oil? or was this just a coincidental bad pump? who knows?Its only 10 minutes from slip to ocean, so admittedly we don't use the motor for extended times on a regular basis, and usually only at low rpms. I'll put it through the paces more aggressivly once this problem is solved. Incidently it created a runaway engine situation and I was lucky to shut her down by smothering the intake - thank God! Hope no damage.DanO'side
