I may need to remove the engine from my old 30 sailboat. No doubt I will attempt to minimize the expense. The engine weighs about 350 lbs. I have never seen this done and do not want make errors in the decision of how to do it. Man-handling seems like an accident looking for a place to happen.
Short of turining it over to a boat yard to just do it, what are the options?
Does the boat need to be on the hard to remove the engine? It seems to me that the only controlled option with the boat in the water would be to use a travel lift.
How do they lift the engines out of boats in the boat yard... with a travel lift, or cherry picker?
I am just trying to make a plan in the event that the engine does need to come out. Any experience that you have had is very welcome.
