Electric Motors
There is a company in Maryland called "Solomon Technologies" that makes an electric motor for use in a sailboat. They currently are producing two sizes, a six HP unit and a ten HP unit. The motor is a unique design, it is called the Electric Wheel. It was originally designed for use in electric vehicles where the motor was going to be built right into the wheel, thus eliminating drive shaft, transmissions, etc. The auto companies didn't pick up on it, but the inventor of the motor has installed it in several sailboats. While undersail the motor is capable of generating power and can recharge the batteries. A typical application would require about ten batteries in series to develop about 120 volts. Torque characteristics of the motor is flat from zero to 1200 RPM, and does not need a transmission as the shaft rpm is about the right amount for a typical propellor.I have looked at this as an alternative to my present Yanmar 3GMD, but its hard to beat. For one thing, according to the standard propellor sizing equations, I need at least 20 hp of engine power for a propellor that can deliver an efficiency 0f 55% in order to acheive hull speed (1.2*Sq Root of waterline). I haven't found one yet, most end up being in the 40 to 45 range.So with the ten hp motor, the best I could do would be less than hull speed.Neverthless, the concept sounds attractive, and when the fuel cells are developed to the point of being practical, this may be the way to go. But for the present, its hard to beat the energy density of a diesel engine.If anyone is interested in this, contact David Tether at ewhel@aol.com for further info.Ernie
