Diesel crusing rpm's
17
Hunter 280 Lake Oologah
I have a new to me Hunter 280 with a 18 HP Yanmar. There was nothing in the owners manual or the Yanmar manual about optimum engine speeds. It says idle is around 750 RPMs and to run at 2500 RPMs to burn excess carbon out after prolonged idling. But are there boundaries on what crusing motor speeds should be?
Sep 26, 2008
566
- - Noank CT.
cruise around 2600 to 2800, max rpm 3600 but should not be at max for long durations
Apr 5, 2011
113
Hunter 34 Tilghman Island, Md
I've always heard that you should run at ~80% of max RPM. Diesels like/want to be run.
Jun 4, 2004
834
Hunter 340 Forked River, NJ
Engine tag
All of the above posts are correct. You can see the manufacturer's recommendation on the engine ID tag - usuallly mounted on the front of the engine. It usually has information about Max and continuous RPM recommendations as well as oil weight.
Aug 20, 2011
17
Thanks to all for responding. Hopefully I can find the engine tag with specifications.:)
Jan 7, 2011
5,677
Oday 322 East Chicago, IN
I have a '96 Hunter 280 with the 18hp Yanmar. I typically run mine at ~3000 RPM's. Pushes the boat at around 6kts. Motored 75+ miles over 2 days back in April when I brought it down from Milwaukee where I bought it. She just ran and ran and ran (and on 1/2 tank of fuel).
