A
Allen
Hey Guys,I just wanted to share an experience I had a few weeks ago. I was heading out on my first big cruise to go from Boston to Hyannis for the Figawi race. I'd taken the boat out twice immediately after launching to make sure all systems survived the winter, but about 25 minutes out on my big cruise my engine (a 2001 Yanmar 2GM20F) sputtered, surged & stalled. I quickly diagnosed there was air in the fuel so I bled the system, got it running for 5 minutes & it quit again.I had a hard deadline to get to the race so I sailed the entire way from Boston to Sandwich on the Cape Cod Canal (docking under sail!) and then sailed out & from Sandwich to Hyannis. I made it to the race on time, but it was a royal pain in the neck.I figured it was bad fuel, but I changed filters 3 times & every time it ran for about 5 minutes & then quit. I started to second guess my "bad fuel" diagnosis, but because the engine was so new (less than 200 hours) I couldn't imagine that an injector or fuel pump or any other mechanical problem could exist.It turns out that the fuel additive I used in the fall for winter layup didn't include a biocide. I had a plankton bloom (diesel bug) in my fuel and there was a LOT of sediment in the fuel. It caused a brand new set of fuel filters to be clogged in about 5 minutes. I couldn't believe it. I ended up pumping out about 12 gallons of old fuel, adding biocide to the empty tank to shock the system & filling with fresh diesel. It now runs perfectly.I'm sharing this story with you guys so you can learn from my mistake. Make sure you take care of your fuel including both a fuel stabilizer AND a biocide additive. A set of filters set me back $33 and I went through 5 of them when all was said & done, along with the headache of worrying about the reliability of my engine.Happy Sailing to All,Allen Schweitzers/v FalstaffC-30 Hull# 632
