Brian
Today I fired up my brand new Nissan 8hp 4 stroke outboard for the first time. Being a powerboater, I am not used to having a manual choke. Long story short, I ran the motor for about 30 minutes with the choke on (pulled out). I was running it in neutral in the driveway for break in. The I realized I forgot to open the choke, and when I opened it the motor ran MUCH smoother and quieter. While the choke was closed, there was alot of black soot coming out from around the prop, enough to turn the white prop black. It kept running for 30 minutes at idle speed while I was in the house, but ran alot rougher and louder than when I closed the choke and it got the proper amount of fuel. It restarted several times with no problem. I am concerned that I may have damaged or shortened the life of the motor. So the question is, could I have damaged the motor by doing this? Also, is it a good idea to run the motor at 1/2 or 3/4 throttle for break in while in neutral, or should break in be done under load while the prop is turning? This is not addressed in the owner's manual. I will greatly appreciate any responses!
